06-08-2017, 16:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2684815 Status: Offline Thanks Meter: 133 | Qmobile 3G2 after formate Imei same Please Help Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 248 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : FF Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x80 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0056 , [TOSHIBA] TC58NYG0S8C FLASH_DIE0 : 0098 00B1 0080 0055 FLASH_DIE1 : 0072 0016 0008 0000 FLASH_LEN : 0x08000000 INT_RAM : 0x00015000 EXT_RAM : 0x04000000 NAND not supported yet for selected operation! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
05-05-2018, 06:16 | #9 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2271452 Status: Offline Sonork: no Thanks Meter: 0 | Qmobile 3G2 mt 6276 after formate Imei same......... write orignal imei very easy DONE with Volcano box use RX TX SELECT BOOT 11 Detect RT TX MT CPU And go to imei tool ....Dont press boot key only press power key ........ Done |
