10-21-2017, 13:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | Qmobile 3G2 Factory File Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 150 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : FF Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x80 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0056 , [TOSHIBA] TC58NYG0S8C FLASH_DIE0 : 0098 00B1 0080 0055 FLASH_DIE1 : 0072 0016 0008 0000 FLASH_LEN : 0x08000000 INT_RAM : 0x00015000 EXT_RAM : 0x04000000 Reading Flash Content now ... Read Ok, make firmware now ... Scatter Configuration info : MT6276 / NAND / DDR Saved to : MT6276_NAND_HEXING76_512256_11A_PCB01_hspa_MT6276_S01.V322_01E_CFZZ_QVGA_QMOB_YY5_V01 Read Done! Done! Elapsed: 00:01:08 Reconnect Power/Cable! DOwnload |
The Following User Says Thank You to Unlockinfo For This Useful Post: |
