01-26-2017, 18:09 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | a800pro 6580 dead after write same f.w how can revive ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 91 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12617CFDBF91F1 Initialize Memory ... CodeDefine : DA_DEVICE_NOT_FOUND [DA_ERROR] : DRAM Configure failed! ErroCode : 0x00BC EMICFG_RET_FAILED Boot Error! try inite preloader /erase/still dead |
01-28-2017, 13:48 | #3 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | AGAIN ERROR............................................. .............v0134 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : gxq6580_weg_l , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : alps Device Model : gxq6580_weg_l Device CPU : MT6580 Device IntName : full_gxq6580_weg_l Device Version : 5.1 Device Compile : 10/27/2016 11:38:22 Þ.Ù Device Project : ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 Device ExtInfo : gxq6580_weg_l Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D12617CFDBF91F1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x00BC EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:16:07 Reconnect Power/Cable! |
01-28-2017, 13:54 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | This FW made from exactly this phone? Seems as not. there is 2 variant : Hw ( mostly ) or Exists other revision of Fw for higher RAM ( 512 / 1024 ) |
01-28-2017, 14:17 | #5 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | اHERE IS BACKUP F.W:MT6580__alps__gxq6580_weg_l__gxq6580_weg_l__5. 1__ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 AND I WRITE A8+ exactlly MT6580__alps__gxq6580_weg_l__gxq6580_weg_l__5.1__A LPS.L1.MP6.V2_GXQ6580.WEG.L_P69-OK |
