Old 12-29-2015, 10:40   #1 (permalink)
bombinson's Avatar
Member: 1973579
Thanks Meter: 30
QMobile a110
hi team, help me recover this phone... i have flashed the phone with NAND backup-ed firmware from same another phone.. Now result is phone is dead..
Card found : S/N : , v0129
Chinese Miracle II [MTK module] v 1.40
Operation : Check / Read Info [ v1.40 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00C800F4000000000000000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:24
Reconnect Power/Cable!
Old 12-30-2015, 05:27   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Now you should write it original FW. Hope, you made "Read FW" with Infinity?
Old 12-30-2015, 06:43   #3 (permalink)
bombinson's Avatar
Member: 1973579
Thanks Meter: 30
Yes i have read fw from same working mobile. But problem doesn't get solved.
Old 12-30-2015, 06:58   #4 (permalink)
JayDi's Avatar
Member: 462970
If SPFT on flashing show "4032" - that mean you read not from "SAME".
Always make ORIGINAL FW backup, when work with clones, which have MUCH versions.
Old 12-31-2015, 05:44   #5 (permalink)
bombinson's Avatar
Member: 1973579
Thanks Meter: 30
Okay thanks for information sir.
Page generated in 0.12931 seconds with 8 queries
