Old 04-20-2016, 16:52   #1 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
Qmobile A120 After flash dead... ?
Operation : Flash [ v1.46 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048600A36DF031CD
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A36DF031CD
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : A532D97B5E80F94B35197C34AF9EB9CF
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4031a , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3816 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000081C40000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4031a.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:01:18
Reconnect Power/Cable!
Old 04-20-2016, 20:13   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Answer in log. Just follow it.
Old 04-20-2016, 20:29   #3 (permalink)
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
sir Flash Erase then flash but same problem .....
Old 04-20-2016, 20:39   #4 (permalink)
JayDi's Avatar
Member: 462970
If there is exists FW's for different HW versions - try them.
If result still same - probably, eMMC is dead.
Old 04-21-2016, 09:33   #5 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
Yes Qmobile A120 Have 2 hardware versions.With factory file both versions flashed ok.but with readed file set dead on diffrent hardware version.so u must search factory file or readed from same hardware phone.picture i take from other thread.
File Type: jpg 12782445_977790478976928_90578320_n.jpg (108.1 KB, 13 views)
Old 04-21-2016, 10:33   #6 (permalink)
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
sir i have this modal .......
Old 04-21-2016, 11:50   #7 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
@Rizwan bro this is v1 set.search same phone read file and flash or search in forum or check EMMC TEST in CM2 for sure EMMC is ok.
Page generated in 0.13861 seconds with 9 queries
