01-20-2016, 14:25 | #1 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1250765 Status: Offline Sonork: NOt Available Thanks Meter: 28 | Qmobile A290 Dead? ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 77 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473261110155A18CA1625F DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! HOw To Back Preloader this set? |
01-20-2016, 14:41 | #2 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Bro file MT6572__QMobile__QMobile A290__QMobile A290__4.4.2__ALPS.KK1.MP7.V1 100% Mobile On Cm2 Write |
The Following User Says Thank You to Suny125 For This Useful Post: |
01-20-2016, 14:50 | #3 (permalink) |
Member: 1250765 Status: Offline Sonork: NOt Available Thanks Meter: 28 | Bro i download Ok Cm2 Readed File but this errod always show me. Wait for phone... Phone found! [ 77 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473261110155A18CA1625F DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
01-20-2016, 15:07 | #4 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Find correct firmware and flash your phone. Also refer this thread, may it it helps you- http://forum.gsmhosting.com/vbb/f296...flash-2028746/ Br. Infinity Box Support Team. |
01-20-2016, 15:15 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | like if you we unable to repair perloader using sp flash tool are cm2 tool its mean firmware which we trying not match with phone firmware ? but if we read same firmware from another same working phone and then we try to repair perloader and its unable to repair then where is the problem ? phone are firmware ? |
02-14-2016, 21:54 | #7 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Imeicodes
Member: 1189070 Status: Offline Thanks Meter: 167 | i facing same problem after flash phone dead .. but phone still connecting and accepting firmware i need working firmware i tried 3g firmware and simple but condition same |
02-15-2016, 22:20 | #8 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Quote:
after seeing your logs maybe i can help u | |
