Old 03-05-2016, 07:30   #1 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 941
Qmobile A290 PreLoader : NOT Active Erased
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A2362E228F
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A2362E228F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 15E5F73084283F26612E9D4A0FA9DC27
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : A290
ProdModel : QMobile A290
Device : A290
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1.P146
Old 03-05-2016, 07:52   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,977
Hello,
Find same firmware and write preloader from it via Init Preloader under Extra-Repair tab.
Br.
Infinity Box Support Team.
Old 03-05-2016, 08:11   #3 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 941
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DRAM configured from ScatFW!
SOC VERIFY : C1
Boot Ok!
SecCfg Passed , 1799
Supported HW by Preloader :
FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX]
BL : Storage supported by BootLoader!
Sending BootLoader ...
Preloader Sent , Init passed
PartTable Init Ok , Count : 14
All Done
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : A290
Device : A290
AndroidVer: 4.2.2
MTKxCPU : MT6572
Done!
Elapsed: 00:00:10
Old 03-05-2016, 08:31   #4 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,976
Hello,
Make HW test and post logs
also try full flash phone
Old 03-05-2016, 08:44   #5 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 941
Originally Posted by syed tuqeer View Post
Hello,
Operation : HW Test [ v1.42 ]
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3747 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040503A2362E228F
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:35
Old 03-05-2016, 10:03   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
Make sure about you use NON boot cable. Not press any keay. If still same - probably, side keys are short.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-08-2016, 07:09   #7 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 941
phone power on ofter flash dead
Old 03-08-2016, 07:12   #8 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 941
Scatter Load Ok , BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : QMobile A290
Device CPU : MT6572
Device IntName : QMobile A290
Device Version : 4.4.2
Device Compile : 11/24/2014 4:40:27 AM
Device Project : ALPS.KK1.MP7.V1
Device ExtInfo : QMobile A290
Ready to Flash!
Operation : Flash [ v1.42 ]
======= Flash
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3739 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:09
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5201ap.bin
PartCount : 0012
Update PMT by user request
Repartition Done!
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:50
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:43
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:12
User selected Preloader file : preloader_s5201ap.bin
Operation : Init Preloader [ v1.42 ]
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartTable Init Ok , Count : 13
All Done
Done!
Elapsed: 00:00:11
======= Flash
Wait for phone...
Phone found! [ 61 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Disabled
Switching to HSUSB
HSUSB Init Ok
BL : Skip checking by User request!
BL : BatteryLevel : 3730 mV
PartCount : 0012
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:55
Update RomInfo done
Done!
Elapsed: 00:03:13
Old 03-08-2016, 08:02   #9 (permalink)
JayDi's Avatar
Member: 462970
Then seek CORRECT FW for it.
Old 03-08-2016, 09:18   #10 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,439
try this preloader
if not work somebody post readed preloader from MMX D321
Page generated in 0.36122 seconds with 8 queries
