05-01-2015, 09:06 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Pakistan
Member: 775524 Status: Offline Sonork: 100.1608849 Thanks Meter: 125 | Qmobile A300 100% flash done by CM2 ======= Flash Files set for flashing : [ MCU ] : MTK6572_1502151134.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048600A382A4B0D1 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A382A4B0D1 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6572 , TARGET ID : 6572 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase disabled Write Flash now ... [ MCU ] : MTK6572_1502151134.bin Init Ok , Sending blocks ... Write done , 2988 blocks sent Done! Elapsed: 00:12:28 Reconnect Power/Cable! |
