01-10-2016, 13:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2012
Member: 1824929 Status: Offline Thanks Meter: 99 | Qmobile A500 Flashing fail ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001153030534A05B0004D3D409F16 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Finish at : [1/10/2016 / 4:54:27 PM] always get this error on many phones and other tool sucessfully flash this phone |
01-10-2016, 14:40 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I can't remove it, because this one error can happen on thjousand and one reason. Starting from bad connection ( like cable inserted not fully ) , battery charge and etc. problems and ending with just "not luck at thin connect try" cases. |
