02-03-2016, 11:00 | #1 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | QMobile A900 MTK6589 Dead Recover Factory File By InfinityBox CM2MTK QMobile A900 MTK6589 Dead Recover Factory File By InfinityBox CM2MTK Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 504E01FE58585830EDE110588FB03828 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 504E01FE58585830EDE110588FB03828 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810E1ED2838B08F [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3604 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x000000008A260200 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_gionee89_dwe_jb2.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:03:20 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:35 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:22 Reconnect Power/Cable! Br Suny125 |
The Following 3 Users Say Thank You to Suny125 For This Useful Post: |
02-03-2016, 11:52 | #2 (permalink) | |
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | QMobile X6i SPD7715 Factory File Write InfinityBox CM2SPD Done QMobile X6i SPD7715 Factory File Write InfinityBox CM2SPD Done Quote:
Br Suny125 | |
