Old 12-29-2015, 07:46   #1 (permalink)
Member: 1892312
Sonork: 100.1651296
Thanks Meter: 76
qmobile a900 NV File
i need qmobile a900 NV File
if anyonehave pls plz upload
Old 12-29-2015, 07:52   #2 (permalink)
rsa7262's Avatar
Member: 2470191
Sonork: 100.1652036
Thanks Meter: 307
A900 Q NVRAM - Download - 4shared - RISING SUN
HERE IS UR FILE...
The Following User Says Thank You to rsa7262 For This Useful Post:
Old 12-29-2015, 08:03   #3 (permalink)
Member: 1892312
Sonork: 100.1651296
Thanks Meter: 76
Infinity Cannot write this file Data error or damage file
Old 03-21-2016, 12:58   #4 (permalink)
Member: 2490362
Sonork: 100.1675622
Thanks Meter: 31
through android miracle box u can write nvrm file
Old 03-21-2016, 13:14   #5 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
100% ok nv file by q a900 MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V6_P26_eMMC - Download - 4shared - ghani bilal
Start at : [3/21/2016 / 4:13:12 AM]
Operation : Write NVRAM [ v1.44 ]
Wait for phone...
Phone found! [ 196 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 4B000115303055359ADD024DD180D580
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00U5
[eMMC] : FLASH_CID : 1501004B355530304D02DD9A80D580D1
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 275FAE8F406AE55AE30B1688419BD351
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[NVCheck] : BBID : MT6583 , NVID : MT6583
[NVM] : Write Ok!
[Info] : NVRAM Repair on erased/damaged phone :
1. Fix Unknown BaseBand
2. Power On phone, check BB state
3. Write NVRAM
4. Repair Security
Done!
Elapsed: 00:00:33
Reconnect Power/Cable!
Old 06-12-2016, 20:21   #6 (permalink)
Member: 2409570
Thanks Meter: 23
After Write NV same Problem NO Service or Emergency Call...
Please Add Proper Solution To Solve Signal Problem,....
Page generated in 0.16059 seconds with 8 queries
