01-24-2019, 15:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2110371 Status: Offline Thanks Meter: 20 | how can solve this techno k8 challenge Card found : 7396D615 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.03 Load IDBase v123080 Ok! Operation : Identify [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM39) MODE : PRELOADER PORT PORT : 39 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : MT6570_INFINITY | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : TECNO : BASE_SECURE | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
01-24-2019, 15:40 | #3 (permalink) |
Member: 2110371 Status: Offline Thanks Meter: 20 | i do that now here is the result Operation : Identify [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM39) MODE : PRELOADER PORT PORT : 39 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
01-24-2019, 16:29 | #5 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Load the custom DA file and post result https://mega.nz/#!4rgzRIJZ!8sJUsyB8M...SInsxbr5jf9x_I |
01-25-2019, 05:30 | #6 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Quote:
01-25-2019, 14:39 | #7 (permalink) | |
Member: 2110371 Status: Offline Thanks Meter: 20 | Quote:
