01-22-2017, 15:24 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: karachi
Member: 1686673 Status: Offline Thanks Meter: 53 | QMobile i6 MT6580 Metal ONE Dead After Flash firmware Write Successfully But After Write Set is Dead I Download Many Flash File But Set Not on plz Help me After Flash Read Info Code: Card found : S/N : ------------ , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050734C8681F1311 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050734C8681F1311 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x3CF96B0240FCA4BC32524551F74A70EA INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased/damaged phone? Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
04-25-2017, 17:00 | #4 (permalink) |
Freak Poster Join Date: Oct 2015 Location: Pakistan Age: 36
Member: 2477331 Status: Offline Sonork: 100.1676088 Thanks Meter: 29 | QMobile i6 MT6580 Metal ONE Dead After Flash Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 99 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505073133B8A9230F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505073133B8A9230F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xBEAA679A3DF80EEDAF55B4645FA3104D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased/damaged phone? Done! Elapsed: 00:00:07 Reconnect Power/Cable! Solution Please ??? |
05-08-2017, 12:48 | #5 (permalink) |
Freak Poster Join Date: Mar 2014 Location: swabi kpk
Member: 2139605 Status: Offline Thanks Meter: 31 | QMobile i6 MT6580 Metal ONE Dead After Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505073118201523C9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505073118201523C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x3E55AE7998C13534A9E7F360B693595F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info! Make "Identify" first! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! |
07-31-2017, 08:07 | #7 (permalink) |
No Life Poster Join Date: Apr 2010 Location: United Arab Emirates ( DUBAI )
Member: 1294044 Status: Offline Thanks Meter: 1,269 | https://www.androidfilehost.com/?fid=457095661767143956 Password www.combinefile.com Combine File 100% Tested Firmware 100% test FIle |
The Following 3 Users Say Thank You to ..::KASHIF::.. For This Useful Post: |
10-26-2017, 11:41 | #11 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | Info read not done Erased/damaged phone? INFO CLEARLY SHOWS THAT PHONE MMC IS DAMAGE OR READONLY STATE NO SOFTWARE WILL WORK ON IT NEED TO CHANGE EMMC AND I6 METAL ONE IS SECURE BOOT AND NOT SUPPORTED BY CM2 HOW IT COULD BE DEAD BY CM2 PLZ DONT SPAM !!! |
12-17-2017, 18:30 | #15 (permalink) |
Junior Member Join Date: Oct 2005
Member: 193088 Status: Offline Thanks Meter: 2 | My 2 i6 metal one phones dead with it..the 2nd one i took the backup also. But after reflashimg the backup fw still dead. Only read light . i also tried the rewriting the preloader.. And flash erase but no luck. To me i think its problem due to secure boot of this model and cm2 version 1.58. I also noticed when you write preloader it gives some partition table error. So its not a hardware error may be. I am still working on it to figure out. |
The Following User Says Thank You to khalidgee For This Useful Post: |
