09-16-2015, 12:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Qmobile i6i GOOGLE verify account not done Code: Card found : S/N : 830C5B0B , v0129 Chinese Miracle II [MTK module] v 1.30 Operation : Check / Read Info [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6580 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6580_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100464A32374D420260B5E47C72A3 DA Stat : v4.2 on BBID : 0x94 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM72J [eMMC] : FLASH_CID : 150100464A32374D420260B5E47C72A3 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x30000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile i6i ProdModel : QMobile i6i Device : QMobile AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_TINNO6580.WE.L MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P4_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 854x480 TOUCH [0] : ektf2k_s5222 TOUCH [1] : ft6336 CAM [0] : gc0310_mipi_yuv CAM [1] : ov5670_mipi_raw_sunwin CAM [2] : ov5670_mipi_raw_cmk CAM [3] : gc2355_mipi_raw MODEM : STOM_MODEM =s5030_hspa_modem_b18_pk_p4 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
09-16-2015, 12:50 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Make few things : Upload scatter from phone ( which CM2 made ) Upload NVRAM , read from phone. Upload preloader file, which CM2 read in factory FW folder. By the way - try reset PrivacyLock. What SW will say as result? |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
09-16-2015, 17:33 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Okara,Punjab {Pakistan}
Member: 578870 Status: Offline Sonork: 100.1625279 MUGHAL MOBILE Thanks Meter: 934 | asad_nomy7;11292083]I have Qmobile i6i with google account verifcation.I format it but same i also flah with Factory files but same as samsung account not gone. Check This Bro 10000000%Tested http://forum.gsmhosting.com/vbb/f296...ution-1992041/ |
The Following User Says Thank You to Muhammad Aleem For This Useful Post: |
09-16-2015, 17:39 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | When I will have some need data - can make it in one button. It can save some time |
09-16-2015, 18:42 | #9 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
Code: Hello. Make few things : Upload scatter from phone ( which CM2 made ) Upload NVRAM , read from phone. Upload preloader file, which CM2 read in factory FW folder. provide this data to jaydi sir maybe if another set of different brand came for same condition and you dont have same working set than what can u do | |
10-09-2015, 18:11 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Infinity-Box - GSM-Forum Check. Read. Try understand. |
10-13-2015, 11:49 | #15 (permalink) |
No Life Poster Join Date: Jun 2013 Location: PK Lahore Panjab
Member: 1965559 Status: Offline Sonork: 100.1622928 Thanks Meter: 1,834 | Qmobile i6i with google account verifcation Done here is Report Code: Inital regs read done Boot Info : BB_CPU_ID : 6580 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6580_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100464A32374D42027E4BD0E372B3 DA Stat : v4.2 on BBID : 0x94 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM72J [eMMC] : FLASH_CID : 150100464A32374D42027E4BD0E372B3 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x30000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear Google Reset Protecton Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Mr..bhatti For This Useful Post: |
