Old 06-13-2015, 11:21   #1 (permalink)
Member: 1824929
Thanks Meter: 99
qmobile i9 stuck on flashing
Operation : Flash [ v1.21 ]
======= Flash
Wait for phone...
Phone found! [ 46 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048600A32C14319F
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A32C14319F
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s5501 , Storage : EMMC
Setting : AFF verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E3800000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5501.bin
Preloader Sent , Init passed
PartCount : 0012
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
stuck here any solution
Old 06-13-2015, 12:13   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Charge battery fully, then try flash again.
Old 06-13-2015, 12:54   #3 (permalink)
Member: 1824929
Thanks Meter: 99
also check with power supply but same problem
Old 06-13-2015, 12:56   #4 (permalink)
JayDi's Avatar
Member: 462970
Maybe - something with phone. Will check error handling.
What SPFT says?
Old 06-13-2015, 13:04   #5 (permalink)
Member: 1824929
Thanks Meter: 99
Old 06-13-2015, 13:30   #6 (permalink)
Member: 1824929
Thanks Meter: 99
any solution.............
Old 06-13-2015, 14:54   #7 (permalink)
JayDi's Avatar
Member: 462970
Yes. Change eMMC ic.
Page generated in 0.16354 seconds with 8 queries
