08-19-2018, 16:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 411034 Status: Offline Thanks Meter: 26 | qmobile lt100 firmware write failed Card found: S/N : 0CF1AA70 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC983x] eMMC [Generic Android 7.x] Infinity SC Firmware Detected FW Size : 3094 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : QMobile Device Model : LT100 Device CPU : QMobile Device IntName : LT100 Device Version : 7.0 Device Compile : 19/12/2017 08:00:13 Device Project : QMobileLT100_MP_19_12 Device ExtInfo : QMobile LT100 Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1B records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... [FlashProc] : Error with code 0x027E00A20000FF5D7E Elapsed: 00:00:26 Reconnect Power/Cable! |
08-21-2018, 10:05 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Make FlashIC Test first. If FlashIC Test passes, either try with Update NV or Erase flash first (remember Erase flash could be risky). Also make sure firmware is correct for your phone variant. Br. Infinity Box Team. |
12-19-2018, 15:44 | #6 (permalink) |
Insane Poster Join Date: Dec 2013 Location: Swat Pakistan Age: 41
Member: 2089757 Status: Offline Thanks Meter: 8 | LT 100 removed frp with miracle box successfully. Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Please Hold BootKey(UP and DOWN),Insert USB cable 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Scanning USB Serial port... SU2Serial Port: COM100 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot41... >>Formating...frp data.. |
