11-26-2018, 14:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Karachi Pakistan Age: 30
Member: 2824001 Status: Offline Thanks Meter: 110 | Qmobile lt100 Flash IC damaged..!! Card found: S/N : 6F1D354D , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC983x] eMMC [Generic Android 7.x] Infinity SC Firmware Detected FW Size : 3094 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : QMobile Device Model : LT100 Device CPU : QMobile Device IntName : LT100 Device Version : 7.0 Device Compile : 19/12/2017 08:00:13 Device Project : QMobileLT100_MP_19_12 Device ExtInfo : QMobile LT100 Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1B records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... [FlashProc] : Error with code 0x027E00A20000FF5D7E Elapsed: 00:00:25 Reconnect Power/Cable! Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Error on Flow Init! Battery/Connection problem? Test NOT PASSED! FlashIc is DAMAGED/BAD! Elapsed: 00:00:52 Reconnect Power/Cable! |
