Old 10-23-2019, 16:16   #1 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 190
Red face Qmobile lt360 flash error
Card found :
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.01
Load IDBase v9215 Ok!
Open : SPD_PROG.xml
Reading package ...
Read package finished!
Created by Infinity-Box (c) 2019
Chinese Miracle II : Spreadtrum / UniSoc Service Module
Device Info file : _Android_info.txt
Patch Level : OPM2.171019.012
Display ID : QMobileLT360_MP_24_12
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-12-05
Build Time : 1545650564
Product Model : LT360
Product Brand : QMobile
Product Name : LT360
Product Device : LT360
Product Manfct : QMobile
Product Info : LT360
Product Board : sp9850ka_1h10
Board Platform : sp9850ka
Operation : Flash Firmware [ v2.01 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : Update PMT : True
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : QMobile : LT360
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
ERROR : FLASH FDL NOT started!
Error : Fail to boot FDL!
Unsupported device with selected fdl! Change settings!
Reconnect Power/Cable!
The Following User Says Thank You to bherkund For This Useful Post:
Old 11-27-2019, 13:34   #2 (permalink)
Member: 1177389
Sonork: 100.1609281
Thanks Meter: 17
my problem same Qmobile LT360 error boot fdl ( fdl unchecked but same problem
The Following User Says Thank You to fayyazu7 For This Useful Post:
Old 11-27-2019, 14:25   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Last version for now is - v2.03
It have ability to ignore internal boots by manual boot selection.
If you SURE about that FW MAY work in that HW - select FW, select in main tab boot/model from model list, which can boot this device and repeat flashing procedure again.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-02-2020, 07:49   #4 (permalink)
Member: 2498409
Thanks Meter: 127
noo any boot in intinitysp2 to flash lt360 mobile
Page generated in 0.13771 seconds with 8 queries
