Old 10-10-2010, 17:34   #1 (permalink)
Member: 273013
Thanks Meter: 47
Qmobile M12 used code_CPU MTK 6253
Dear Infynity team!
I need read code Qmobile M12 Cpu 6253. You can help me problem?
Thx infy team
log:
COM3 [VCP8] selected
module v3.24
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
interesting cpu type found: 6253:8A02:8A00
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
detect custom parameters...
detect project-id...
project-id: PN-SC_1V8_CN_LLNUMLD_205_YYMMDD_CAM_MCPMCP_O
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: unexpected answer:
startup code area #1 is invalid
startup code area #1 detection done
rom info ver: 07
sw version: PIANO_S02_PCB01_GPRS_MT6253_S00.PN-SC_1V8_CN_LLNUMLD_205_YYMMDD_CAM_MCPMCP_O.BIN_FLNK 5N2833ATB_AQ12000
project-id: PN-SC_1V8_CN_LLNUMLD_205_YYMMDD_CAM_MCPMCP_O, CC7989F5
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
area size: 14Mb
number of areas/bytes to read: 1:00E00000
file saved: C:\Documents and Settings\Begin\Desktop\PIANO_S02_PCB01_GPRS_MT6253 _S00.PN-SC_1V8_CN_LLNUMLD_205_YYMMDD_CAM_MCPMCP_O.BIN_FLNK 5N2833ATB_AQ12000__firmware_20101010-232033.B0M.bin
Disconnect...
done
Finished, time used: 7 min 56 sec
Remove/Install battery now !
Read fullflash choose whole flash chip
RapidShare AG, Cham, Switzerland
Old 10-10-2010, 18:57   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
working under 6253 CPU support
Old 10-11-2010, 03:21   #3 (permalink)
Member: 273013
Thanks Meter: 47
Choose uses/lock code.
unlock method: read code > not ok
COM3 [VCP1] selected
module v3.24
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6239 NOR
19200 autodetect
Initializing [346C:0001]...
CPU: MT346C
high speed boot On
error: hardware is not supported: [0000346C:00000001]
Can not initialize test mode, possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method
error: operation failed !
Finished, time used: 9 sec
Old 10-11-2010, 12:16   #4 (permalink)
Member: 148515
hello!
Old 10-23-2010, 23:50   #5 (permalink)
Member: 1043909
Thanks Meter: 60,926
We are waiting for test reports and comments here: http://forum.gsmhosting.com/vbb/f425...ments-1123803/
How to use Nokia tool - with connection 6-7 pin or not?.. 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-20-2000 19:53
How can I use AT command control Nokia6110?Help me! arnom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-15-2000 07:35
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? telefonman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-13-2000 20:06
how can we use *.scr files to unlock shadow77 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-27-1999 03:13
Startup Logo to be used as Operator Logo Beachbum Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-09-1999 18:43
Page generated in 0.16195 seconds with 9 queries
