03-10-2019, 14:59 | #1 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Pakistan
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | qmobile qinfinity prime frp not supped.............. Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 0699 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0003 PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
03-11-2019, 06:23 | #2 (permalink) |
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
03-11-2019, 07:38 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Bro,Plug & play ended in mtkv1.58 Now you have to use Brain and test different BASE's /Custom DA& other SW Features. |
The Following User Says Thank You to Kirumira For This Useful Post: |
