Old 11-22-2016, 11:18   #1 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 9
Qmobile s1 lite frp lock
Qmobile s1 lite frp lock any solution
Old 11-27-2016, 06:55   #2 (permalink)
Member: 1532868
Sonork: 100.1640331
Thanks Meter: 36
yes have solution
use sm2spd and select Boot 11 means 7731 android 6.x
and do formate
ur problem solve........
Old 12-17-2016, 11:52   #3 (permalink)
Member: 2394595
Thanks Meter: 24
Not supported on infinty i check
Old 12-17-2016, 20:52   #4 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
WHAT NOT WORK
PLS POST LOGS TO CHECK
WBR
sahil2000ind
Old 12-18-2016, 12:10   #5 (permalink)
Member: 2394595
Thanks Meter: 24
Phone found! [ 42 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Reconnect Power/Cable!
Old 12-18-2016, 12:10   #6 (permalink)
Member: 2394595
Thanks Meter: 24
with all boot sc7731 this error
Old 12-19-2016, 07:29   #7 (permalink)
Member: 2394595
Thanks Meter: 24
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_pike_modem_AndroidM_mir_balun.dat
File : DSP_DM_G2.bin
File : SC8800G_pike_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : LOGO.bmp
File : CHARGE.bmp
File : cache.img
File : u-boot.bin
File : SC7720_UMS.xml
Load Ok!
i think sc7720 cpu not supported yet
The Following User Says Thank You to GSM WORK For This Useful Post:
Old 12-22-2016, 10:21   #8 (permalink)
Member: 307225
Thanks Meter: 59
By Ticking (Reset Via SVC) Option
(Reset Done But FRP Not Clear)
Old 12-24-2016, 10:59   #9 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
FRP Cleared manually by option .. but how to read its firmware ?
Old 12-24-2016, 11:08   #10 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Card found: S/N : CEE6926A , v0134
Chinese Miracle II [SPD module] v 1.22
Operation : Read FullFlash [ v1.22 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 248 ]
Port Opened
Sync...
Initial Boot Failed!
3. Insert cable
Port Opened
Sync...
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Old 12-26-2016, 05:33   #11 (permalink)
Member: 1532868
Sonork: 100.1640331
Thanks Meter: 36
100% spurted
Bro its sported i chaked and tested meny s1 lite phones
Contect me
Skype aamir.ali124
Sonork 100.1640331
Old 12-26-2016, 05:35   #12 (permalink)
Member: 1532868
Sonork: 100.1640331
Thanks Meter: 36
i have 100% selustion
3. Insert cable
Port Opened
Sync...
3. Insert cable
Port Opened
Sync...
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Bro contect me i solve ur problem
I already tested meny s1 lite phones
Skype aamir.ali124
Sonork 100.1640331
Old 12-26-2016, 15:55   #13 (permalink)
Member: 2394595
Thanks Meter: 24
Any one reply here plzzzzzzzzzzz
Old 01-01-2017, 07:18   #14 (permalink)
Member: 2394595
Thanks Meter: 24
any one success report about frpppppppppppppppppppp
Old 01-01-2017, 07:19   #15 (permalink)
Member: 2394595
Thanks Meter: 24
Page generated in 0.32066 seconds with 8 queries
