12-04-2015, 14:29 | #1 (permalink) |
Freak Poster Join Date: Jun 2012 Location: (United States Of Islam)
Member: 1775513 Status: Offline Thanks Meter: 128 | QMobile T480 Cant read Pac file Try To Read Info But Software show Card found: S/N : 9F382061 , v0129 Chinese Miracle II [SPD module] v 1.07 Operation : Read FullFlash [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 28 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 28 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.07 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 28 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
12-05-2015, 12:18 | #6 (permalink) |
Member: 1775513 Status: Offline Thanks Meter: 128 | Qmobile t500 read pac file done but not read spd 8830 Qmobile T480 if you have free time pls chek via teamviwear or not chek pls write cm2 not support |
12-05-2015, 12:21 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I'm very patient, but last time : If you can't read manual - then for you it will be supported NEVER. If you read it and understand - then you can even not wait for any update and service phones now and here. Choose is yours. |
