12-02-2015, 06:59 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | Qmobile T480 not read info or format Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
12-02-2015, 12:02 | #9 (permalink) |
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | i tried al;l but some times it stuck and sometimes it gives error..it has same CPU as Qmobile M82i....m82i is working fine with cm2 where T480 does not so where is problem |
12-02-2015, 12:15 | #10 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
