06-08-2016, 07:12 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Qmobile w50 read flash problem ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [6/7/2016 / 8:44:19 AM] Start at : [6/7/2016 / 8:44:47 AM] Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 6/7/2016 / 8:45:50 AM ================================================== ======= Chinese Miracle II [SPD module] v 1.18 Start at : [6/7/2016 / 8:46:13 AM] Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 94 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [6/7/2016 / 8:46:23 AM] Start at : [6/7/2016 / 8:46:29 AM] Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 6/7/2016 / 8:47:35 AM ================================================== ======= Card found: S/N : Chinese Miracle II [SPD module] v 1.18 Start at : [6/7/2016 / 8:48:15 AM] Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [6/7/2016 / 8:48:29 AM] Start at : [6/7/2016 / 8:48:48 AM] Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [6/7/2016 / 8:48:59 AM] Start at : [6/7/2016 / 8:49:16 AM] Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! Finish at : [6/7/2016 / 8:49:23 AM] Start at : [6/7/2016 / 8:49:51 AM] Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 6/7/2016 / 8:52:06 AM ================================================== ======= Card found: S/N : Chinese Miracle II [SPD module] v 1.18 Start at : [6/7/2016 / 8:52:52 AM] Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 94 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [6/7/2016 / 8:52:59 AM] Start at : [6/7/2016 / 8:53:09 AM] Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 94 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [6/7/2016 / 8:53:19 AM] Start at : [6/7/2016 / 8:54:58 AM] Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 95 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:20 Reconnect Power/Cable! Finish at : [6/7/2016 / 8:55:18 AM] |
06-08-2016, 09:32 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | What about slrd files, tried with that? http://forum.gsmhosting.com/vbb/11832026-post7.html http://forum.gsmhosting.com/vbb/11795950-post5.html Br. Infinity Box Support Team. |
