09-10-2015, 16:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Not Supported Mobile Here. M Module (via USB Not supported hard to connect with rx tx but I managed) tried twice thrice with ( MT6205-6239 NOR & MT6250-6253 etc) Code: module v4.47 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Operation: SP-unlock unlock method: read codes interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6252 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: B1021C_MP_F2_PK_F1_V8 H/W board version: TINNO52_10A_GEMINI_HW Melody version Melody V0.0 Version: B1021C_MP_F2_PK_F1_V8 ==================== New firmware found (v4.47, database date: 27.03.2014): B1021C_MP_F2_PK_F1_V8 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure imei... done 136 byte(s) read imei #1: 35325705004910400000 imei #2: 35325705036504700000 detecting structure simlock #1... error: detection failed (16 tries) detecting structure simlock #2... error: detection failed (3 tries) Shutdown... done Finished, time used: 1 min 21 sec Remove/Install battery now ! Code: Operation : Read UserCode [ v1.29 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 00C3 BB_CPU_HW : 0001 BB_CPU_SW : 4A59 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 00000000000000000000000000000000 BROM Protocol Version : FF Setting... Setting done , result code 0x430E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found :( Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
