05-12-2015, 10:51 | #1 (permalink) |
Banned Join Date: Nov 2013
Member: 2058900 Status: Offline Thanks Meter: 177 | QMobile X25 MTK 6572 Factory File Card found: S/N 5342:0128 Chinese Miracle II [MTK module] v 1.19 Operation : Read Flash [ v1.19 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A1212871D7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A1212871D7 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : X25 ProdModel : QMobile X25 Device : X25 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_s4011.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / s4011 / EMMC FW Size : 929 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__QMobile__QMobi le X25__X25__4.4.2__ALPS.KK1.MP6.V1\ All done! Done! Elapsed: 00:05:27 Reconnect Power/Cable! Operation : Read PatternLock [ v1.19 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A1212871D7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A1212871D7 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 2400 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 35789 Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to AdnanSattar302 For This Useful Post: |
08-28-2015, 09:34 | #4 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote: here is tested factory firmware:- QMobile X25 Factory Firmware https://mega.nz/#!rg9zUKKK!PoF2U_fcM...Xkpw8RFjAamoSI wBw, Nasir Javed | |
09-27-2015, 08:41 | #5 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Quote:
The Following User Says Thank You to naveed ali For This Useful Post: |
09-27-2015, 17:11 | #7 (permalink) |
Freak Poster Join Date: Nov 2011 Location: rwp
Member: 1686412 Status: Offline Sonork: 100.1664625 Thanks Meter: 212 | https://mega.nz/#!mRcykZwa!wVL_6_zei...lH1br8f1BJX0r4 here is tested file |
The Following 3 Users Say Thank You to leosthebest007 For This Useful Post: |
10-12-2015, 06:43 | #8 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2265797 Status: Offline Sonork: 100.1646791 Thanks Meter: 119 | bad paster im3022 this is bad shared link becose this is job for this man so carefull |
The Following User Says Thank You to tahirshan77 For This Useful Post: |
