08-13-2016, 13:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 980720 Status: Offline Thanks Meter: 15 | qmobile X500 MT6582 restart problem |
08-13-2016, 15:20 | #3 (permalink) |
Member: 980720 Status: Offline Thanks Meter: 15 | Operation : HW Test [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D420182D8D03D71F5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D420182D8D03D71F5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xAAAD94617A801A6E96094B02B702B37B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3730 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMVX7 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 1501004B3758564D420182D8D03D71F5 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! |
08-13-2016, 15:32 | #6 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: West Africa Ng Gh RCI
Member: 2243088 Status: Offline Thanks Meter: 38 | next time do this Quote:
at 1- when you receice just read file on flash option tick scatter on BIN OPTION 2- TICK read factory file option and press read firmware save and use that same file to flash the fone you will see | |
