-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   qmobile z10 flash file plz (http://forum.gsmhosting.com/vbb/f296/qmobile-z10-flash-file-plz-2064319/)
chandmob 03-12-2016 09:28
qmobile z10 flash file needed plz
qmobile z10 after flash dead plz help me ....
z10 n spd verion
InfinityHelp 03-12-2016 12:04
z10 n spd verion
Do you know what is required firmware version ?
chandmob 03-14-2016 10:36
sorry i had not checked of this version .. only check lolypop . plz check mobile pic and then u will confirm the problem
naveedsialkoti 03-14-2016 11:32
if u show me flashing log with cm2 dongle then i will upload for u
z10 n spd verion
and before the post open the brain what are u posting q mobile z10 spd?:p:p
http://i63.tinypic.com/w9io9x.jpg
chandmob 03-16-2016 11:15
sorry broo 4 late ... not proper read file
plz up load the file
Operation : Read Flash [ v1.43 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 520001154D4231321E3D06429F9966C2
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:01:24
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:49
masterRt1994 03-16-2016 12:13
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:01:24
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:49
br :)
masterRt1994
chandmob 03-17-2016 15:14
same error .... plz upload the file
khanzada606 03-17-2016 22:33
Seems phones volume button are pressed inside might u are not pressing
pull them out while flashing
zulqaif jutt 11-08-2017 09:50
flash any file but first past this file you delat old PRELOADER and past this one oka past you result
https://mega.nz/fm/zRcmiD6B
Page generated in 0.24711 seconds with 5 queries
