Old 03-12-2016, 09:28   #1 (permalink)
Member: 2097226
Thanks Meter: 4
qmobile z10 flash file plz
qmobile z10 flash file needed plz
qmobile z10 after flash dead plz help me ....
z10 n spd verion
Old 03-12-2016, 12:04   #2 (permalink)
Member: 148515
Thanks Meter: 13,934
z10 n spd verion
Do you know what is required firmware version ?
Old 03-14-2016, 10:36   #3 (permalink)
Member: 2097226
Thanks Meter: 4
sorry i had not checked of this version .. only check lolypop . plz check mobile pic and then u will confirm the problem
Old 03-14-2016, 11:32   #4 (permalink)
naveedsialkoti's Avatar
Member: 2375239
Sonork: 100.1662985
Thanks Meter: 950
if u show me flashing log with cm2 dongle then i will upload for u
z10 n spd verion
and before the post open the brain what are u posting q mobile z10 spd?
Old 03-16-2016, 11:15   #5 (permalink)
Member: 2097226
Thanks Meter: 4
sorry broo 4 late ... not proper read file
plz up load the file
Operation : Read Flash [ v1.43 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 520001154D4231321E3D06429F9966C2
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:01:24
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:49
Old 03-16-2016, 12:13   #6 (permalink)
masterRt1994's Avatar
Member: 2105681
Sonork: Stoped Using...
Thanks Meter: 901
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:01:24
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:49
br
masterRt1994
Old 03-17-2016, 15:14   #7 (permalink)
Member: 2097226
Thanks Meter: 4
same error .... plz upload the file
Old 03-17-2016, 22:33   #8 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 335
Seems phones volume button are pressed inside might u are not pressing
pull them out while flashing
Old 11-08-2017, 09:50   #9 (permalink)
Member: 2497168
Sonork: zulqaif jutt
Thanks Meter: 11
flash any file but first past this file you delat old PRELOADER and past this one oka past you result
https://mega.nz/fm/zRcmiD6B
Page generated in 0.31493 seconds with 7 queries
