Old 05-22-2016, 14:40   #1 (permalink)
Member: 1326820
Thanks Meter: 22
qmobile z10 flashing error Repartition Failed!
Operation : Flash [ v1.47 ]
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 520001154D423132E03D064269A083C2
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMB12
[eMMC] : FLASH_CID : 150100523231424D42063DE0C2831369
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 93096E098330BDDF9AF7CBEDC7469DF9
INT RAM : 0x00020000
EXT RAM : 0xC0000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6753 , Project : ALPS.L1.MP3.V2.21_6753.65U.G_P35 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Disabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3417 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 5
Erase : 0x0000000001C80000-0x0000000000080000
Erase : 0x0000000001D80000-0x0000000003280000
Erase : 0x0000000005200000-0x0000000000600000
Erase : 0x0000000006000000-0x0000000000A00000
Erase : 0x000000000B000000-0x000000039F780000
Flash Pre-Erase Done, time used : 00:00:15
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : PRELOADER
Preloader Sent , Init passed
PartCount : 0017
Update PMT by user request
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:31
Reconnect Power/Cable!
Old 05-22-2016, 16:04   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,770
If Flash Erase done and that changed nothing - eMMC is dead. Need change.
Old 05-23-2016, 16:00   #3 (permalink)
Member: 1326820
Thanks Meter: 22
emmc test result is here sir...
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BMB12 , 0x747C00000 , 29820 MiB
[eMMC] : CID : 150100523231424D42063DE0C2831369
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:51
Old 05-23-2016, 17:00   #4 (permalink)
JayDi's Avatar
Member: 462970
So, then you should select CORRECT FW for that phone.
Old 11-08-2017, 09:49   #5 (permalink)
Member: 2497168
Sonork: zulqaif jutt
Thanks Meter: 11
flash any file but first past this file you delat old PRELOADER and past this one oka past you result
https://mega.nz/fm/zRcmiD6B
Page generated in 0.27761 seconds with 7 queries
