10-27-2016, 16:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Gujranwala Age: 25
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | qmobile z14 flash with cm2 after dead SOLUTION? PLEASE Code: Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC Files found : 16 , Set to Flash : 15 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : Z14 Device CPU : MT6755 Device IntName : Z14 Device Version : 6.0 Device Compile : 7/23/2016 4:48:22 PM Device Project : GBL7533QM_0203_T5468 Device ExtInfo : Z14 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207B911DA8A8309 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xB4A11DC7F5126CE200BD859BFF9FA3E2 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Ok Flash Partition : MD1IMG Image Flash Ok Flash Partition : MD1DSP Image Flash Ok Flash Partition : MD1ARM7 Image Flash Ok Flash Partition : MD3IMG Image Flash Ok Flash Partition : LK Image Flash Ok Flash Partition : LK2 Image Flash Ok Flash Partition : BOOT Image Flash Ok Flash Partition : LOGO Image Flash Ok Flash Partition : TEE1 Image Flash Ok Flash Partition : TEE2 Image Flash Ok Flash Partition : SECRO Image Flash Ok Flash Partition : SYSTEM Image Flash Ok Flash Partition : CACHE Image Flash Ok Flash Partition : USERDATA Image Flash Ok Flash Write Done, time used : 00:02:33 Done! Elapsed: 00:02:51 Reconnect Power/Cable! |
10-29-2016, 07:05 | #3 (permalink) |
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207B911DA8A8309 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xB4A11DC7F5126CE200BD859BFF9FA3E2 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : Z14 ProdModel : Z14 Device : Z14 AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : GBL7533QM_0203_T5468 SECURITY : IMEI_SW [1] : 352837080004137 IMEI_SW [2] : 352837085004132 BTMAC Addr : B898F76D1BFD WiFi MAC : 045604BDF18F EXTRA : LCD : Not info available :( LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : imx135_mipi_raw CAM [1] : ov5648_mipi_raw CAM [2] : s5k2p8_mipi_raw CAM [3] : ov8858_mipi_raw MODEM : gionee6755_66_m_lwctg gionee6755_66_m_c2k LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
10-29-2016, 21:26 | #5 (permalink) |
Freak Poster Join Date: Dec 2013 Location: LARKANA PAK Age: 35
Member: 2080580 Status: Offline Thanks Meter: 42 | Bro change file. . https://mega.nz/#!50w3XJgI!LQV-mwoGo...6-2hHc1sgu2W8M |
10-30-2016, 07:44 | #7 (permalink) | |
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | Quote:
11-29-2016, 15:29 | #8 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | z14 dead Help Plzzzzzzzzz info Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42071290DEFF83C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xD1BA4C793639CBE901D246DE901768A9 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
11-30-2016, 06:36 | #10 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | To Alive Phone Again Do This In SPflash Options / Download Active USB Cheksum & Storage Ceksum And Now Try Firmware Upgrade in letest SPflash tool |
12-04-2016, 15:33 | #11 (permalink) |
Junior Member Join Date: Jan 2011 Location: pattoki pakistan
Member: 1503423 Status: Offline Thanks Meter: 5 | i recover dead set z14 i have the 100 percent working perfect method of z14 revover after dead with flash.testing on 4 dead phone. 00923126007788 contect me . very tough work only can do with team viewer |
12-04-2016, 15:39 | #12 (permalink) |
Member: 1503423 Status: Offline Thanks Meter: 5 | i have solotion. this happen when encription is on. after flas set dead.. not posssible reecover on any file thats is on internet provided. i tried with seven files but fail.now i recover after six days working |
12-05-2016, 07:53 | #14 (permalink) | |
please tell me | |
