08-15-2015, 18:17 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile Z4 (MT6589) Reading Factory Firmware error. Code: Operation : Read Flash [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 49000115303055321961174161804166 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : A00U2 [eMMC] : FLASH_CID : 15010049325530304117611966418061 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile ProdModel : Z4 Device : QMobile AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_gionee89_dwe_jb2.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Error] : Bad EXT data Looks like unusable file , break! Read Ok , collect info Brand : QMobile ProdName : QMobile ProdModel : Z4 Device : QMobile AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 File conversion error, file already exists! Saved as default! Done! Elapsed: 00:05:06 Reconnect Power/Cable! -------------------------------------------------------------- Qmobile Z4 (MT6589) IMEI Permanent Repaired. |
08-15-2015, 18:58 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Error mean some problem with userdata part. If it encrypted or damaged. I finished some stuff fo that, will activate soon. It will allow read such cases, repair bad FS, stuck and e.t.c. |
08-16-2015, 06:31 | #3 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | ok some info: this phone is fully formatted (format with sp flasher without preloader) and flashed official release and , clear emmc in factory mode. and after repair IMEI with infinity box read operation was made. |
08-16-2015, 08:19 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That mean "encrypted" fs, right. http://forum.gsmhosting.com/vbb/11225887-post2.html |
08-16-2015, 08:30 | #5 (permalink) | ||
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
wBw, Nasir Javed | ||
