Old 07-10-2015, 12:06   #1 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Clone IPhone6 Plus ATE Signaling Test..
hi supporters..
while trying to writing security device entered to this mode and not exiting..i tried all key combination..
Start  at : [10.07.2015 / 12:06:16]
Operation : Check / Read Info [ v1.23 ]
Wait for phone...
Phone found! [ 2 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B4A5330304D0812B376C67F17
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00SJ
[eMMC] : FLASH_CID : 1501004B4A5330304D0812B376C67F17
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : alps
ProdName  : keytak72_cwet_lca
ProdModel : keytak72_cwet_lca
Device    : keytak72_cwet_lca
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : 604755_550.3G.EN.CN.V30.C12
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Finish at : [10.07.2015 / 12:06:30]
Start  at : [10.07.2015 / 12:06:58]
Operation : Repair Security [ v1.23 ]
Wait for phone...
Phone found! [ 2 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Old 07-10-2015, 12:16   #2 (permalink)
Member: 556768
Thanks Meter: 157
re insert battery or let battery get drain then recharge.
Old 07-10-2015, 12:36   #3 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
it is covered by case.. i mean unplagable the battery..
pc detects the device as Android Gadget Driver.. maybe supporters fix or solve this pb..
Old 07-10-2015, 12:40   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Seems as all latest phones doesn't want work in AT mode. Will try finish other methods soon.
Old 07-10-2015, 12:42   #5 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
i see.. i need to wait drain battery..
Old 07-10-2015, 13:11   #6 (permalink)
JayDi's Avatar
Member: 462970
If you want power it off - Press and hold "VolUp" + "VolDown" and "PowerOn" near 30-40 seconds.
Old 07-11-2015, 08:56   #7 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
it didnt work.. i tried all key combiination by pressing 1 min. or more..
and i have never wrote security area.. is there any pb by me or software..?
Old 07-11-2015, 08:59   #8 (permalink)
JayDi's Avatar
Member: 462970
I've tested much phones with embded battery. This combination fully work on them.
Old 07-11-2015, 09:16   #9 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
yes this combination working many phones but on this device..
Old 07-11-2015, 10:11   #10 (permalink)
JayDi's Avatar
Member: 462970
Then should be "reset" button. Even hidden.
At now working on other repair method for eMMC phones. Hope to finish in 1.25.
Old 01-05-2017, 18:10   #11 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
zte blade v6 try to repair imei ATE Signaling Test cant power off using combination
any solution
Page generated in 0.17271 seconds with 8 queries
