07-26-2017, 12:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: karoondi khairpur pakistan
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | qmoblie x33 frp help need Phone found! [ 15 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:17 Reconnect Power/Cable! |
07-26-2017, 13:49 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Which cpu is inside phone? You can read info in SVC mode for info. Select CPU under setting according to phone cpu, try with/without ALTLDR mode. Br. Infinity Box Team. |
07-26-2017, 14:49 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | 1. use search button. (there is recent post of same model ) 2. put phone in fastboot and reset frp using AST v1.01 Module. 3. select correct boot from setting and do required operation (Qmobile x33 have sc77xx cpu) select sc773x emmc 4.x or 5.x) 4. if you failed to select correct boot in setting , download below file and select pac in flash tab and do desire operation. http://130.211.210.249/tmp/x33.7z size: 13.1 MB |
07-27-2017, 07:15 | #8 (permalink) |
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! |
