04-29-2019, 06:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | qphone q65 4sim flash file read dond and free for all Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 64 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 752C803F18FCFF802265B7A012994CBF BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : L86S_Q65_PCB01_gprs_MT6261_S00.L86S_Q65_V1.bin FileVersion : L86S_Q65_V1 Saved to : C:\InfinityBox\CM2MTK\Read_out\L86S_Q65_PCB01_gprs_MT6261_S00.L86S_Q65_V1.bin Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
04-29-2019, 08:05 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
04-29-2019, 15:59 | #4 (permalink) | |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
