03-18-2017, 12:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 43
Member: 50643 Status: Offline Thanks Meter: 117 | Qualcomm Module [QLM] v 1.11 err Why is it not read Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 02ECE388 ID_BLOCK_I : 007050E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : F1CBEE80F9C9E5388BDDD8D70F236A90 ID_BLOCK_L : 7B9C937F3DB46F955A26ECF64036725A Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to proton For This Useful Post: |
03-18-2017, 12:20 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | which model / brand is this phone ? for your question why this is not read? answer is in log Unsupported SecureType! |
The Following User Says Thank You to malka4u For This Useful Post: |
