05-18-2017, 11:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | SPD Serious Request Spd773x phones with Android v5xx & v6xx Read Firmware must be improved,we encounter problems like software Not Responding. phone goes to charging mode Hope next update will be made simple Thank you. |
05-18-2017, 18:10 | #3 (permalink) | |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Quote:
The only problem I faced was with SC7731C CPU which has been fixed a long time ago. You need to study the tool well and know how to use it, e.g., if you need to read firmware, you must disconnect and reconnect phone to pc 3 times as tool demands before getting successful operation and also be able to identify your phone's boot key for connection. Last edited by Kwesi_Roy_GH; 05-18-2017 at 18:16. | |
05-18-2017, 18:31 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There can be drivers or cable problem, probably. I not see reason make any changes of things which are work well. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
05-18-2017, 20:56 | #5 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | This is obvious indicates what i mean,All operations runs fine except Reading FLASH to the mentioned ANDROID VERSIONS am using Win7 32bit,& Xp sp3 same problem Respected Jaydi. @Kwesi_Roy_GH Dont try to oversmart,I understand what to do & how. |
05-18-2017, 22:17 | #6 (permalink) | |
As per your comment, you can perform all operations except reading flash. My question is, why can you perform all operation but can't read flash? There is tricks involved in being able to read flash on this CPU. In fact, reading flash on this CPU is the most difficult and trickiest operation ever especially when the phone's battery is non-removable. and if you take your time and study the tool well, you will be successful. I have experienced your complaints before and know what you are talking about. If you need help on this, you can contact me. I will help you. | |
05-19-2017, 06:20 | #7 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Yes.. Quote:
It is not recommended and convince able that every user complaint about it. If Mr.Jaydi see 4 to 5 reports then this should be noticed. I also face such problems while reading or writing with these C.P.U but not write here. May be Mr.Jaydi could have so much time and check his PM to find a message from my side. I know this guy "Kirumira" very helpful for all Users of Infinity Box he can not be on mistake. B/R Sheraz... | |
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post: |
05-19-2017, 14:32 | #10 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Is this a SIMPLE METHOD AS I WAS REQUESTING ??? I dont know what you loose if this is Improved !!! | |
The Following User Says Thank You to Kirumira For This Useful Post: |
05-19-2017, 18:56 | #12 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | FINALLY I TESTED,PROBLEM WAS POPUP WINDOW MISGUIDING online photo storage ONLY BOOT KEY WORKS NOTE: If you HOLD BOTH VOL- & VOL+ keys,phone boots automatically to charging mode,this was working in OLD METHOD OF READ FLASH AFTER ENABLING USB DEBUGGING[ADB MODE] TESTED ON KIMFLY M2 [VOL + IS BOOT KEY] Here we go; READ INFO Code: Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : t13_x163_bp236_64_4_dt Model Brand : SPRD Model Device: t13_x163_bp236_64_4 AndrVersion : 5.1 BaseBand CPU: T13_BOPAI_64_4 CompileDate : 17/11/2016 09:55:58 Project Ver : 20161117 Model Ext : M2 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : t13_x163_bp236_64_4_dt Model Brand : SPRD Model Device: t13_x163_bp236_64_4 AndrVersion : 5.1 BaseBand CPU: T13_BOPAI_64_4 Project Ver : 20161117 Model Ext : M2 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2124 MiB Saved to : C:\Users\KIRUMIRA\Desktop\T13_BOPAI_64_4_t13_x163_bp236_64_4_5.1_20161117_M2\ Done! Elapsed: 00:18:04 Reconnect Power/Cable! Code: Infinity SC Firmware Detected FW Size : 2124 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : SPRD Device Model : t13_x163_bp236_64_4 Device CPU : t13_bopai_64_4 Device IntName : t13_x163_bp236_64_4_dt Device Version : 5.1 Device Compile : 17/11/2016 09:55:58 Device Project : 20161117 Device ExtInfo : M2 ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731C_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Update NVM image : nvitem_w.bin Update NVM Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin Write Data ... Write Data Ok! Update NVM image : nvitem_wcn.bin Update NVM Data Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : oem.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:04:21 Reconnect Power/Cable! Code: Operation : Convert InfinitySC to SPRD PAC [ v1.26 ] Target : T13_BOPAI_64_4_t13_x163_bp236_64_4_5.1_20161117_M2 Step #1 : Identify MEMORY : eMMC LAYOUT : eMMC NORMAL Step #2 : Select logic Select Logic : SC7731 Step #3 : Processing data Build PAC [ADD FILE] : nvitem_w.bin [ADD FILE] : nvitem_wcn.bin [ADD FILE] : prodnv.img [ADD FILE] : u-boot-spl-16k.bin [ADD FILE] : sc7731C_CP0_modem.bin [ADD FILE] : DSP_DM_Gx.bin [ADD FILE] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [ADD FILE] : logo_480x854.bin [ADD FILE] : fblogo_480x854.bin [ADD FILE] : boot.img [ADD FILE] : system.img [ADD FILE] : oem.img [ADD FILE] : cache.img [ADD FILE] : recovery.img [ADD FILE] : userdata.img [ADD FILE] : u-boot.bin Build Ok! Result : 0x0018 Sign PAC ... Sign Ok! FW compiled! Elapsed: 00:02:13 Saved to : T13_BOPAI_64_4_t13_x163_bp236_64_4_5.1_20161117_M2.pac Done! |
05-19-2017, 19:54 | #13 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Quote:
this is true, when software again say to connect only use + or - boot key(this depend on handset), then reading start properly. | |
05-19-2017, 20:00 | #14 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | @kirumira, You must have known this, actually every SPD phone uses different key combination as boot key. Some requires vol + only, some vol - only, and some (can say 60% phone) require both vol + & - simultaneously. Hence, regardless the popup instruction, you need to connect the SPD phone, pressing the required boot key 3 time during the read flash operation when prompted by the software. Actually the most convenient way is First do read info, and connect phone with boot key combination... Here you will get to know about the boot key exactly for that phone... And during read flash, you need to use that key only while connecting the phone to PC 3 times... P.s: Purpose to create this post is to only make the things clear and not hurt/disrespect any person experience or anything like that |
The Following User Says Thank You to chandanps18 For This Useful Post: |
06-05-2017, 09:36 | #15 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | best way i know is once phone keep turning it self on..then if the battery is removable..remove it and try with no battery..100% solution for mtk..some spd works like too... when u want to read.. better,first read info and then when device goes to flash mode .... use same mode to read |
