10-15-2015, 04:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | Question About Mt6575 i8552 I have A Question About Mt6575 i8552 Could Not Read Write Flash file Not Read Nvran..Also Can Not Unknown Base band...in i8552 mt6575 Code: Card found : S/N : 685*** , v0129 Chinese Miracle II [MTK module] v 1.33 Operation : Fix Unknown BaseBand [ v1.33 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 150100534A5330304D00640B191860C7 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial Info Read not done! Erased phone or wrong init settings? Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
10-15-2015, 08:56 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | I had also same phone and read file no problem.but after use AV phone hang on logo then i write backup again.means no problem in read file. Code: Operation : Read Flash [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 150100534A5330304D0045B410F3CFC5 [eMMC] : FLASH_EXT : 00100000/00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_hexing75_jb.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : EBR2 [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img ProdName : GT-I8552 ProdModel : GT-I8552 Device : GT-I8552 AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.MP.V1.16 [ScatCFG] : MT6575 / V1.0.0 / hexing75_jb / EMMC FW Size : 547 MiB Scatter saved to : C:\Documents and Settings\Noman\Desktop\MT6575___GT-I8552__GT-I8552__4.1.2__ALPS.JB.MP.V1.16\ All done! Done! Elapsed: 00:05:30 Reconnect Power/Cable! |
10-15-2015, 10:50 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as it have some unknown structure or something else. Have no idea, it became ancient phones and probably - some functions may not work correct. |
