R268 invalid sim and invalid imei this mobile on invalid sim but after formating the imei is not dected.i sent u the formating and write imie log and also link of my r268 firmware.please check it COM9 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 353924546677760 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E203:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 05 ver. sw 1: R268_FN_PCB01_GPRS_MT6225_S00.R268AR_GH_S311_F12_V 05_090729.BIN ver. sw 2: R268AR_GH_S311_F12_V05_090729, 00000000 code offset: 00000000 ffs offset/size: 00E60000/001A0000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E60000 standard ffs/eeprom offset confirmed: 00E60000 detecting ffs/eeprom size... ffs/eeprom size: 001A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E60000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R268_FN_PCB01_GPRS_MT6225_S00.R268AR_GH_S311_F12_V 05_090729__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\New Folder\R268_FN_PCB01_GPRS_MT6225_S00.R268AR_GH_S31 1_F12_V05_090729__ffs_20091203-203840.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "repair imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 679 sec Remove/Install battery now ! Check your country laws before use this option ! In some countries this operation may be prohibited ! You must think serious before continue ! Do you understand above text well and want to continue ? operation aborted http://www.4shared.com/file/16520213...6225_S00R.html |
hello! make IMEI change in mode-1 or 2 Mode 3 is last thing to try |
hello! mode-1 must be done on Powered On phone. Mode-2 on powered Off. please post here both logs, we will help with advice |
Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 106 sec |
hello! Ok, post here method-2 LOG |
I also have phone with same problem Here log method 2 : COM2 selected module v3.04 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 353923030000000 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9703:000A status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 1 min 33 sec Remove/Install battery now ! I think phone must enter TEST MODE, but its turn on.... |
Hello bro first do the complete ON your phone then click to write. Try this with new software version 3.04 Write in mode-1 |
hello! what cable do you use as interface? |
Have 3 cable type : Infinity Box cable standart RJ45 cable PinFinder Xintel This is not cable problem , bcs other same phone with no0rmal IMEI work perfect... |
@*Diablo* your joke was not smart due to in some cases we can give a good advice to user right after he tell to us what cable he have used. Anyway, even in this situation, I have an advice for you: download latest ChineseMiracle v3.06 and try it now. |
