Old 12-04-2009, 09:36   #1 (permalink)
Member: 383211
Thanks Meter: 99
R268 invalid sim and invalid imei
this mobile on invalid sim but after formating the imei is not dected.i sent u the formating and write imie log and also link of my r268 firmware.please check it
COM9 [VCP0] selected
module v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "repair imei"
imei write method: mode-3
imei write channel: imei #1 for dual sim/mono CPU
new imei: 353924546677760
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:E203:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
slowest
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info protocol ver: 05
ver. sw 1: R268_FN_PCB01_GPRS_MT6225_S00.R268AR_GH_S311_F12_V 05_090729.BIN
ver. sw 2: R268AR_GH_S311_F12_V05_090729, 00000000
code offset: 00000000
ffs offset/size: 00E60000/001A0000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E60000
standard ffs/eeprom offset confirmed: 00E60000
detecting ffs/eeprom size...
ffs/eeprom size: 001A0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E60000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: R268_FN_PCB01_GPRS_MT6225_S00.R268AR_GH_S311_F12_V 05_090729__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\New Folder\R268_FN_PCB01_GPRS_MT6225_S00.R268AR_GH_S31 1_F12_V05_090729__ffs_20091203-203840.B0E.bin
Backup required data Done
====> Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "repair imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "repair imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 679 sec
Remove/Install battery now !
Check your country laws before use this option !
In some countries this operation may be prohibited !
You must think serious before continue !
Do you understand above text well and want to continue ?
operation aborted
http://www.4shared.com/file/16520213...6225_S00R.html
Old 12-04-2009, 23:03   #2 (permalink)
Member: 148515
Thanks Meter: 15,061
hello!
make IMEI change in mode-1 or 2
Mode 3 is last thing to try
Old 12-05-2009, 08:44   #3 (permalink)
Member: 383211
Thanks Meter: 99
hello!
i check also mode 1 and 2 but it is not work also
Old 12-05-2009, 18:34   #4 (permalink)
Member: 148515
hello!
mode-1 must be done on Powered On phone.
Mode-2 on powered Off.
please post here both logs, we will help with advice
Old 12-06-2009, 10:15   #5 (permalink)
Member: 383211
Thanks Meter: 99
hello!
this the log of mode1 and 2.i also flashed it with this cable and also change baudrate also and also conect it manually pinout
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
error: connection failed !
If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect")
operation failed !
Finished, time used: 106 sec
Old 12-06-2009, 17:27   #6 (permalink)
Member: 148515
hello!
Ok, post here method-2 LOG
Old 01-09-2010, 08:34   #7 (permalink)
*Diablo*'s Avatar
Member: 59173
Sonork: 100.1585568
Thanks Meter: 225
I also have phone with same problem
Here log method 2 :
COM2 selected
module v3.04
imei write method: mode-2
new imei: 353923030000000
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:9703:000A
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 1 min 33 sec
I think phone must enter TEST MODE, but its turn on....
Old 01-09-2010, 10:18   #8 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello bro first do the complete ON your phone then click to write.
Try this with new software version 3.04
Write in mode-1
Old 01-09-2010, 21:15   #9 (permalink)
Member: 148515
hello!
what cable do you use as interface?
Old 01-13-2010, 07:47   #10 (permalink)
*Diablo*'s Avatar
Member: 59173
Sonork: 100.1585568
Thanks Meter: 225
hello!
=) Then you will ask - what color of cables ?
Have 3 cable type :
Infinity Box cable standart RJ45 cable
PinFinder
Xintel
This is not cable problem , bcs other same phone with no0rmal IMEI work perfect...
Old 01-13-2010, 14:46   #11 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
@*Diablo*
your joke was not smart due to in some cases we can give a good advice to user right after he tell to us what cable he have used.
Anyway, even in this situation, I have an advice for you: download latest ChineseMiracle v3.06 and try it now.
5230 boot display SIM card invalid ATF success with good repair! 20442044 Advance-Box 3 06-09-2015 09:56
1200 and 1208 invalid sim and sim card regi fail plz help hayjamaloo Nokia Digital Core Technology 4 ( DCT-4 ) 12 03-19-2015 10:31
1100 Invalid SIM and not charging IvailoShopov Nokia Hardware & Hardware Repair 12 04-01-2009 10:58
how to fix E50-1 after flash i got Invalid sim and the IMEI is correct??? tsarkh HWK 4 12-03-2007 06:43
how to fix E50-1 after flash i got Invalid sim and the IMEI is correct??? tsarkh Federal One 1 05-12-2007 18:14
Page generated in 0.38592 seconds with 8 queries
