06-30-2017, 11:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Yu 5010 dead:- CUSTOMER IS SAYING THE PHONE WAS WORKING AND SUDDENLY IT GOT DEAD I TRIED TO FLASH WITH CM2 BUT CAN'T FLASH READ INFO Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BFCD0C2 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 452EE7AD2A6CFD611749B2706722C4BA ID_BLOCK_L : 21477413EA78B3BDD4ABA915816E6C6F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000075700000 [ eMMC 2 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Error : Failed to read initial info! Erased/Damaged device??? Check cable, connection and drivers! Reconnect Power/Cable! Code: ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BFCD0C2 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 452EE7AD2A6CFD611749B2706722C4BA ID_BLOCK_L : 21477413EA78B3BDD4ABA915816E6C6F Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000075700000 [ eMMC 2 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 153 Flashing now Flashing : NON-HLOS.bin ProgStart : start 131072, num 94947 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! ALSO TRIED WITH QFIL BUT CAN'T FLASH ANY HOPE TO REVIVE IT WBR sahil2000ind |
