10-11-2018, 09:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | rda gallite 8809 phone lock code problem Chinese Miracle II [RDA module] v 1.05 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 70022005 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C Boot Done! Elapsed: 00:00:28 Done Reconnect Power/Cable! Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 70022005 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 70022005 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 70022005 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
The Following User Says Thank You to lerner_ For This Useful Post: |
