11-07-2018, 17:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | RDA SP CPU NOT DETECTED by RDA MODULE PLEASE HELP ME JayDi i did install all driver properly but when i press V+ & Power button device manager showing only below the picture read mark ''2''com port but RDA module not detect. |
11-07-2018, 17:43 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | This is not and RDA device or drivers installed not correct. Should be LibUsb32/64 section with device inside. |
11-07-2018, 18:16 | #3 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | sir i did install this driver C:\InfinityBox\CM2RDA\Drivers\SmartPhone\x64 i did before this same phone with RDA module but after i re-setup WIN now not detected. Mobicel Metro is the same as this phone |
11-07-2018, 18:53 | #4 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | Please tell me which driver can be detected this phone with your RDA module. AST module log:- Infinity-Box Android Service Tool [AST] v1.03 Operation : Identify (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device Info : Vendor : Rdamicro Model : Metro Device : etau Android : 4.4.2 Product : etau Brand : Mobicel Serial : 5561fe0c4d8384ca Build_tm : Tue Dec 6 13:51:20 CST 2016 DisplayID : KOT49H Patch Ver : KOT49H Hardware : rda8850e CPU rel : armeabi-v7a SIM Card : ABSENT BaseBand : RDA850e RIL ver : android reference-ril 1.0 USB Conf : mtp,adb Sys USB : mtp,adb FS Crypt : unencrypted Done! Elapsed: 00:00:09 |
11-07-2018, 18:54 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Send me VID/PID from those 2 devices, which appear in ports. BTW with AST module you can set in recovery and make wipe from it. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
11-07-2018, 19:15 | #6 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | sir today I'm lucky man, because of i get your instant help. Device USB\VID_0525&PID_A4A9&MI_00\6&1d10f581&0&0000 requires further installation. Device USB\VID_0525&PID_A4A9&MI_02\6&1d10f581&0&0002 requires further installation. |
11-07-2018, 21:32 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It something very customized, unfortunately can't do anything fast for this device. Try do as explain before via reboot to recovery then wipe. |
