Old 06-15-2015, 08:54   #1 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 370
mtk 6571 write flash not supported pls add this
Operation : Read Flash [ v1.21 ]
Wait for phone...
Phone found! [ 227 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 002C00BC009000660054000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x10000000
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0082 , [SAMSUNG] KF98G16Q4X
[NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Break by user
Done!
Elapsed: 00:00:16
Reconnect Power/Cable!
Load File
Bad file detected!
Load File
Bad file detected!
Page generated in 0.10457 seconds with 8 queries
