11-20-2015, 07:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Read backup error.. need help.. i have here X-BO model V5... system error.. after flashing, handset is only white screen.. im now trying to read backup from the same handset.. (working phone) but getting this error.. logs: Code: Card found : S/N :parengBok , v0129 Chinese Miracle II [MTK module] v 1.36 Operation : Check / Read Info [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 700100533130303034084F7CD80952B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 700100533130303034084F7CD80952B5 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : V5 ProdName : V5 ProdModel : V5 Device : V5 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n EXTRA : LCD [0] : hx8389b_qhd_dsi_vdo LCD [1] : hx8389c_qhd_dsi_vdo LCD [2] : hx8389c_v2_qhd_dsi_vdo LCD [3] : nt35517_qhd_dsi_vdo LCD [4] : otm9605a_qhd_dsi_vdo LCD [5] : ili9807_qhd_dsi_vdo LCD [6] : jd9261_qhd_dsi_vdo_adc LCD Res : 960x540 TOUCH [0] : ft6336_gesture TOUCH [1] : GT9XX TOUCH [2] : msg2133 CAM [0] : gc0328_yuv CAM [1] : gc0329_yuv CAM [2] : gc2035_mipi_yuv CAM [3] : ov5645_mipi_yuv CAM [4] : gc2155_yuv CAM [5] : gc0310_yuv CAM [6] : ov2685_mipi_yuv CAM [7] : gc2145mipi_yuv CAM [8] : s5k4ecgx_mipi_yuv MODEM : yuanda72_cwet_kk_hspa_850_2100_gps_coclk_switch LOCALE : en_US en_IN fr_FR it_IT es_ES et_EE bn_BD de_DE nl_NL cs_CZ pl_PL ja_JP zh_TW zh_CN zh_HK ru_RU ko_KR nb_NO es_US da_DK el_GR tr_TR pt_PT pt_BR rm_CH sv_SE bg_BG ca_ES en_GB fi_FI hi_IN hr_HR hu_HU in_ID iw_IL lt_LT lv_LV ro_RO sk_SK sr_RS uk_UA vi_VN tl_PH ar_EG fa_IR th_TH sw_TZ ms_MY af_ZA zu_ZA am_ET hi_IN en_XA ar_XB fr_CA km_KH lo_LA ne_NP sl_SI mn_MN hy_AM az_AZ ka_GE my_MM Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read Flash [ v1.36 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 10 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 700100533130303034084F7CD80952B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 700100533130303034084F7CD80952B5 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : V5 ProdName : V5 ProdModel : V5 Device : V5 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_yuanda72_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin #18360 : Data CRC Error : EC71 , 1F1A Error while reading block! Something went wrong :( Read error :( Operation Failed Elapsed: 00:04:11 Reconnect Power/Cable! need guide on how to read scatter or bin backup.. thanks! |
11-20-2015, 07:26 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Need close all rest software, like managers and etc. , then check usb drivers and charge battery. Error related to connection problems. |
