03-14-2016, 10:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | read data error code:Read failed, error code : 0x04 i received a MTK PHONE 6582 like wiko hang . but custommer need a backup for photo here the log how i can solve my problem i have the flash for this phone but i need all photo before flash Code: Card found : S/N : 47C678DF , v0130 Chinese Miracle II [MTK module] v 1.42 Operation : Read UserData [ v1.42 ] PhoneBook : Enabled PhoneBook : VCFv3 Format output Enabled Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040500D693F11161 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040500D693F11161 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 38AB50F425094FACF084D2EAB396D3E7 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : PhoneBook extraction Step #1 Step #2 Read Ok, PhoneBook records extracted : 116 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook mariem.txt Write : 116 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook mariem.csv VCF Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook mariem.vcf VCFv3 Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook mariem_v3.vcf Processiung : User Photo/Video/Records extraction Read failed, error code : 0x04 Operation Failed Elapsed: 00:00:35 Reconnect Power/Cable! Operation : Read UserData [ v1.42 ] PhoneBook : Enabled Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040500D693F11161 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040500D693F11161 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 38AB50F425094FACF084D2EAB396D3E7 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : PhoneBook extraction Step #1 Step #2 Read Ok, PhoneBook records extracted : 116 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook.txt Write : 116 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook.csv VCF Saved to : C:\InfinityBox\CM2MTK\PhData\MT6582_PhoneBook.vcf Processiung : User Photo/Video/Records extraction Read failed, error code : 0x04 Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! |
03-14-2016, 10:59 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Seems as phone have 2 filesystem, which store data. In second stored photos. Right now - you can readour full flash dump, then use some data recovery tools for extract data from it. We work on DDirect for those type of phones, something will follow soon. |
06-01-2016, 07:28 | #3 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | HI, Any update available for this situation? Facing same problem here. Code: Operation : Read UserData [ v1.48 ] Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50305858585810A9E1CD00B057 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810A9E1CD00B057 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x6C4F2A78963F107468BF0AB84ED0C6BC INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : User Photo/Video/Records extraction Read failed, error code : 0x04 Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
