01-04-2016, 09:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Quang Tri- Viet Nam
Member: 723166 Status: Offline Sonork: 100.1590944 Thanks Meter: 129 | read factory file htc 728g(MTk 6753) not done! Card found : S/N : xxxxxx , v0129 Chinese Miracle II [MTK module] v 1.39 Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! Operation : Flash [ v1.39 ] ======= Flash Nothing to flash! Select file first! Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6753 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6753_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2003 Boot Error! Operation Failed Elapsed: 00:00:34 Reconnect Power/Cable! please hepl me! thank! |
01-04-2016, 10:23 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Press and hold BOTH volume keys, then connect cable. Should work. In theory. FW in result - NOT possible to flash back - I think, it surelly kill phone!!! But you can make all rest operations. Possible, dump writing will work and not kill phone. |
