12-13-2016, 08:56 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1143383 Status: Offline Thanks Meter: 53 | Questions to experts, how to work with CM2 Qualcomm Tool I am running windows 7 32 bits. I have not been able to work with CM2 QLM. So let me ask the following questions : 1) Is a smartphone in EDL mode when in the device manager you see "Qualcomm 9008 (COM xxx)"? 2) Why can not I switch from the "Qualcomm 9008 driver" to the "Emergency driver" even though I do ? 3) How to force EDL Mode by point test ? Examples and photos if possible. 4) How will I be able to unbrick my Huawei qualcomm while the ROMs for CM2 Qualcomm Tool are not available anywhere on the Internet? (There are only ROMs update.app). |
12-13-2016, 09:25 | #2 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | First uninstall "Qualcomm 9008 driver". Run EmergencyDownloadDriver.exe. Then manually select C:\InfinityBox\CM2QLM\Drivers\MANUAL_INST_XP DONE. |
12-13-2016, 14:20 | #6 (permalink) |
Member: 1143383 Status: Offline Thanks Meter: 53 | 1) I downloaded the driver InfinityBox_update_CM2QLM_Drivers_v1.00.7z from the support of the infinity box. 2) I installed it on the PC ===> the result is that now I find in the folder C: \ InfinityBox \ CM2QLM \ Drivers : - The folder MANUAL_INST_XP - the EmergencyDownloadDriver.msi, WinUsbCoInstallers.msi, WinUsbCompatIdInstaller.msi, and WinUsbDriversExt.msi files 3) I installed the four drivers one after the other 4) Now when I connect my Huawei Y530-U00 to the PC and I look in the window of the device manager, I only see the RELINK HS-USB QDLoader 9008 (COM115) driver. I uninstall it and when I reconnect my device, I still only see the devilish driver RELINK HS-USB QDLoader 9008 (COM115) !!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!! Je vais éclater en mille morceaux. Hhhh |
12-13-2016, 16:03 | #7 (permalink) |
Member: 1143383 Status: Offline Thanks Meter: 53 | The installation of the "Nokia Emergency Connectivity" driver is now successfully completed. Here are the steps: 1 °) I uninstalled the "EmergencyDownload" driver from "Programs and Features" in the "Control Panel". 2) I installed "EmergencydDownloadDriver_New.msi" from the ATF Box. Now when I connect my Huawei to the PC, I see "Nokia Emergency Connectivity" under the category "Universal Seria Bus Devices" in Device Manager. I was able to do a Identify and a Format FS in CM2 QLM. But the misfortune is that I do not have the ROM for my Y530-U00 that suits CM2 QLM. I only have the ROM (update.app) that goes with a memory card. |
