Old 11-02-2016, 19:34   #1 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 658
read firmware done but error on write mt6577
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D42071A85C4FD5329
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0x153EBC90590220521FFAEA25157DC489
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Main PMT update failed!
Operation Failed
Elapsed: 00:00:13
Reconnect Power/Cable!
untick repartition
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Ok!
Checking and verifying PMT info
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000001A80000
Erase : 0x0000000001BC8000-0x0000000004000000
Erase : 0x0000000007000000-0x0000000000040000
Erase : 0x0000000007800000-0x0000000002C00000
Erase : 0x000000000A900000-0x0000000E83EFBE00
Flash Erase Done, time used : 00:00:03
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Failed!
Region Configuration Failed! Bad FlashFiles or HW problem?
Operation Failed
Elapsed: 00:00:30
Old 11-03-2016, 12:46   #2 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 658
any solution?????????
Old 11-03-2016, 14:57   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,975
Hello,
Make Flash IC test.
Br.
Infinity Box Support Team.
Old 11-03-2016, 15:32   #4 (permalink)
komalraj's Avatar
Member: 1755126
Thanks Meter: 37
HTC D830u 6735cpu boot error prob with infinity cm2 dongal,pless help me,,any dear member| how can this htc d830u frp lock prob,,,,
Old 11-03-2016, 15:38   #5 (permalink)
komalraj's Avatar
Member: 1755126
Thanks Meter: 37
Chinese Miracle II [MTK module] v 1.51
Operation : Check / Read Info [ v1.51 ]
Wait for phone...
Phone found! [ 168 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
[DA_ERROR] :
Boot Error!
Operation Failed
Elapsed: 00:00:11
Old 11-03-2016, 15:39   #6 (permalink)
komalraj's Avatar
Member: 1755126
Thanks Meter: 37
htc d830u 6735cpu boot error prob with cm2
Old 11-03-2016, 15:58   #7 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 658
Operation : HW Test [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:28
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BM41C , 0xE8F800000 , 59640 MiB
[eMMC] : CID : 150100524331344D42071A85C4FD5329
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:17
i read firmware from this device and try to re write it back but its failing why??
Old 11-03-2016, 16:03   #8 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 658
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Ok!
[AP] : Initial info read Ok!
Brand : Gtel
ProdName : SL8
ProdModel : SL8
Device : SL8
AndroidVer: 6.0
MTKxCPU : MT6755
MTKxPRJ : WBL7531TL_0402_T5514
EXTRA :
LCD : Not info available
LCD Res : 1920x1080
TOUCH [0] : GT1XX
CAM [0] : imx135_mipi_raw
CAM [1] : ov5648_mipi_raw
CAM [2] : s5k2p8_mipi_raw
CAM [3] : ov8858_mipi_raw
MODEM : gionee6755_66_m_lwctg gionee6755_66_m_c2k
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:09
firmware write done with sp tool with format all and download but write fails with cm2
after write device not powering on...
this model is same as Gionee s8
Old 11-04-2016, 08:49   #9 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 658
Please team.. The file bricked my device
Old 11-06-2016, 07:39   #10 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 658
Phone successful flash with original service center firmware... Now its ok but for test i backup again with cm2 and flash with sp tool since cm2 failed to write flash and set dead again... Please fix this
Old 11-06-2016, 10:19   #11 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
Next time specify device info, instead that whole useless cutted logs.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-13-2016, 16:02   #12 (permalink)
Member: 1898834
Sonork: abdelhakim.ch
Thanks Meter: 14
salam
can you give please the link of original service center firmware you used to slove your problem.
Page generated in 0.31441 seconds with 7 queries
