Old 12-30-2018, 12:10   #1 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
Read flash error: access is denied
it happens many times ,when i read flash using CM2MTK i get this error at the end of process
Old 12-30-2018, 16:50   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Make sure software is added in trusted list of antivirus & no other software is trying to access CM2 software.
You can also try to save file in any other location.
Br.
Infinity-Box Team.
Old 12-31-2018, 06:24   #3 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
bro this i always face this error wile reading fac firmware but other tools read fac firmware without any issue i tried to change firmware save path but i didnt work but some times it works its a strange issue am i doing somthing wrong ?
Old 12-31-2018, 15:25   #4 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
I closed antivirus ,and changed save path several times but didnt solve it
Old 12-31-2018, 15:55   #5 (permalink)
Member: 1043909
Thanks Meter: 60,921
What is the CM2MT2 installed version ?
Old 12-31-2018, 15:56   #6 (permalink)
Member: 1043909
Originally Posted by Arslanmayo View Post
.. i tried to change firmware save path but i didnt work but some times it works its a strange issue am i doing somthing wrong ?
Are you sure you have changed save path ?
Old 12-31-2018, 15:56   #7 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
you need to be administrator in you PC or run soft as admin
Old 12-31-2018, 20:08   #8 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
It's the latest version v1.58
Old 01-01-2019, 09:19   #9 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Install latest CM2MT2 v2.03 and check result. Legacy support has already started in CM2MT2, so better use latest version.
Br.
Infinity-Box Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.19128 seconds with 8 queries
